I Trigue 5600 Setup Help
6 Mar 2006
Recently purchased a set of these speakers, set them all up (or so I thought) but no sound appears to be coming through them, unless I turn everything up to MAX in which case there appears to be some sort of constant bass line.
Everything looked to be installed into the right sockets when I double checked but I guess it can't do any harm to check again. Also the light is on the volume control handset which suggests it isn't an issue with no power?
Anyway, desperate help required.
