I want 2 screens but need advice
20 May 2007
Hey everyone
Ive got the money together to buy 2 monitors for my comp
I want DVI inputs, but also be able to use VGA on the monitors
Ive been lookin at the Samsung 940BW
Its a 19inch widescreen monitor, now heres where i need some help
Is 19 inch too big??? bearing in mind im goin to spend a fair bit of time sat in front of these doin uni work
Do i want widescreen or would normal be better when using 2 screens??
Second of all - The monitors have good ratings but is there anything i **** be looking out for on the spec?? cos with monitors i really cant tell the difference in any of them cos i dont know what to look for
So any help would be awesome
Hope to hear from you guys soon
Byyeee
whats your budget cus tbh the hanns g hw191d is great and cheap i have one dvi and vga they are wide screen but i say once you try it you wont go back to 4:3 ever again.
wide screen will probably be better any ways as working with documents etc will give a bit mor room.
Ive probably lookin at £150 each so £300 in total
Are you recommending the Hannsg cos uve used them before?? or are they a better spec??
Only reason i ask is i have a samsung at the mo, but office im working at is using hannsg so jus wondered if they are similar quality or if hannsg is better.
Thanks fors the help D.Roberts
yeah well i do a lot of programming cos of uni and i have so many screens open at once, 2 screens *** really help, and everyone i know who has 2 says that cudn't go back
Also dont know if uve heard of beryl - if not check out youtube and jus type in beryl, but cant wait to set it up on my machine and get cubes spinning on both of the screens
i have the same moniter i recomended look it up on ocuk its got great reviews for the price.....samsung is probably better but who cares when it cost less.
Heya i did order my monitors, i went for the samsung ones just cos ive had samsung monitor before and i liked it.
Should be arriving tomorrow hopefully and also bought myself a couple of hard drives cos im running a lil low on space
