Mini's are far tougher, and are harder to scratch. Also have more storage.Bigsy said:which is superior in every single way I can think of.
Caged said:See what the Apple Factory Outlet has on Wednesday morning.
Phnom_Penh said:Mini's are far tougher, and are harder to scratch. Also have more storage.
Maybe, but they don't look like you've polished them with a hedgehog after a few days of use.Sparky191 said:The nano Sound Quality is a lot better. But if you are only using a low bitrate files and low end earphones I guess thats not an issue.
why not? theres loads to choose from on there..Joebob said:i aint using fleabay!
Phnom_Penh said:Maybe, but they don't look like you've polished them with a hedgehog after a few days of use.![]()
If you want something that sounds good, get a Sony Nwa-608 or the new iAudio. If you want something that looks good get a Nano.Sparky191 said:Thats only a problem is you are going to walk around looking at it not listening to it. Though personally I wouldn't buy either. You can buy a case/skin that will protect it if you're that worried about it.
A2Z said:why not? theres loads to choose from on there..
Phnom_Penh said:If you want something that sounds good, get a Sony Nwa-608 or the new iAudio. If you want something that looks good get a Nano.
Its not as good as other flash players on the market.Sparky191 said:Whats wrong with the way the nano sounds?
Phnom_Penh said:Its not as good as other flash players on the market.
