Hi all,
I am hoping you will be able to help me, I want to get back into programming (I haven't really done any since uni apart from SQL queries).
I thought the best way to get back into it is to create a little project for myself, which is to build a complaint management system!
Features I would like of my program
SQL back end to save the information.
Ability to log time spent on complaints
Ability to generate standard letters from the system, but pulling through complainant information such as name and address.
Ability to save letters against the complainant to be viewed again at a later date.
Ability to capture investigation information through standard forms.
I need some advice what GUI I can use. I have no restrictions on whether it is web based or standalone. Also if anyone can give pointers where I can look to research how to produce documents from the system that would be great.
