If you want cheap, then you should go with AMD.
AMD Athlon X2 5050e Socket AM2 45W
ASROCK A780GM-LE 780G Socket AM2+
That will do everythign you need for about £100inc.
Or if you want so stay with Intel, get a GeForce 9300 Socket 775 board for about £80. Better than buying a cheaper board and an external GPU.
