I want to go wireless
Assuming that Virgin Media is the Cable connection which comes with its own modem, yes. But i wouldnt buy a belkin. Id buy anything but a belkin. (Ive had terrible experiences with the brand in the past).
Yes, cable (the dark blue modem) but I was told Belkin was pretty good, thanks for the warning though
I use Linksys, WRT54GL. Never had any bother with it. Its my gateway and DHCP server for the 24 port switch. I use the wireless for my laptop, and the range is pretty decent.
I hope whoever told you that isn't a friend. Belkin are complete dross. Netgear or Linksys, whichever you prefer, but make sure you buy matching adapters and router.
