I want to overclock my GFX..worth it?
30 Jul 2004
East Sussex, UK
Howzit Guys.
I've currently got the current spec machine:
Intel Core 2 Duo E4400 @ 2.8Ghz
2 x 1GB DDR2 667 Memory
XFX 8800GTS 320MB XXX version (Pre-Clocked card)
Also running Windows Vista Ultimate.
At the moment, most games run just fine. The obviouse one, being Crysis that doesn't run 100%. With everything on high it's just playable. :p
So, was just wondering..would it really be worth it to see what I can get out of this card or just leave it? :)
If I was to overclock it, what tools do you guys recomend I use?
Thanks all!
yea overclocking always helps, but what res do you play at?
btw is that the furthest you can get your e4400? or have you not tried pushing it?
I play @ 1280 x 1024.
Yes, I have gotten it to 2.9Ghz, not 100% stable. Think it's the mainboard or memory or PSU..donno. :(
