- 27 Sep 2022
- London
As per title, I would like to upgrade my CPU but I am not sure if it is worth it or how I am supposed to do it anyway. I'd appreciate any help. Which information do I need to post?
Hi, whats current cpu and motherboard? what is your budget?As per title, I would like to upgrade my CPU but I am not sure if it is worth it or how I am supposed to do it anyway. I'd appreciate any help. Which information do I need to post?
What I plan to do with my PC? work and gaming, hopefully lots of it
my GPU is a RTX 3080
It was, and I'm not entirely sure I need an entirely new one now, but I am curious to know my options and maybe make it happen if the advantages outweigh the costs.What kind of work do you do? That's a very powerful (and very expensive, when it was new) workstation CPU.
I am a teacher and do 3d modeling/very limited animation as a side hustle.
Thank you. Are you saying AMD + nvidia would be a good combo?
That sucks. so I'd actually have to end up getting a new system for a CPU upgrade?
Pretty much yes. You might be able to bring some components across (like RAM) but the PSU will be a very specific to that OEM.That sucks. so I'd actually have to end up getting a new system for a CPU upgrade?
I didn't yet, as I'm assuming Blender isn't the 3d modelling program I use, yes?Did you run Blender and compare your scores to systems similar to yours and other newer platforms ?
I'm sorry, didn't I already give the name/number of CPU and motherboard? or what am I missing?If you can give us the model name/number
Oh it's the 2017 model of the Alienware Area-51.The system, if I google the motherboard it brings up several alternatives for the system and I don't know which one it is.
I feel that its performance has degraded, maybe it could be a software issue, but I'm concenred about a system format.Your PC should still be great so what in particular is making you want to upgrade the CPU? Which 3D modeling program do you use?
