I would appreciate any guidance on the following build ~(£2k)
16 Aug 2005
Hi all,
My trusty gaming computer has unfortunately died (it was purchased in 2016 so has had a good life).
I would really appreciate anyone casting an eye over the components below and offering any changes or advice. I already have a large case from my large build which I am planning on reusing.
This computer will just be used for gaming.
1 X Intel Core i5-13600K (Raptor Lake) Socket LGA1700 Processor - Retail - £319.99
SKU
: CP-6AV-IN
1 X Asus ROG Strix B760-F Gaming WIFI (LGA 1700) DDR5 ATX Motherboard - £209.99
SKU
: MB-6KD-AS
1 X Corsair Vengeance 32GB (2X16GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit - £99.95
SKU
: MEM-CRS-01147
1 X Corsair RMe Series RM1000e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020264-UK) - £152.99
SKU
: CA-27P-CS
1 X WD Black SN770 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T3X0E) - £74.98
SKU
: HD-58F-WD
1 X Gigabyte GeForce RTX 4070 Ti SUPER Eagle OC 16GB GDDR6X PCI-Express Graphics - £869.99
SKU
: GRA-GIG-01549
1 X WD 4TB Red Pro 7200rpm HDD 256MB Cache Internal NAS Hard Drive (WD4003FFBX) - £136.99
SKU
: HD-555-WD
1 X Arctic Liquid Freezer II High Performance CPU Water Cooler - 360mm - £119.99
SKU
: HS-07D-AR
Grand Total: £1,984.87
what's the 2tb spinning disk for? you could grab a 2tb sata SSD for not much more or just go full M.2
why 64gb of ram if you only game and why CL45... grab a good 32gb 6000mhz CL30 kit for £100
14th gen intel is fantastic but i would still grab a 7800x3d
2tb SSD the P3 Plus is a little faster and cheaper
i would buy that
the only thing i would change is buy a single 2tb SSD, you can add more latter if needed..
take that £200 and swap the 4070 ti Super, for a 4080 Super.
