I would like to build a top spec HTPC ......
11 Jun 2004
Middlesex, London
Hi,
Sorry - It's another 'spec me'
I would like to build a top spec HTPC - But it must be small and silent - So ideally based on a M-ATX Board and case etc..
What do you suggest?
Thanks
Just need a silent cpu cooler which fits the case. You could take the ram down to 2gig and obviously you might not need all that hard drive space. The only thing I'm not sure about is how the case screen connects to the computer.
http://upload.yhack.net/image/9915_Untitled.jpg[mg][/QUOTE]
That case can fit an ATX mobo if you want it to ;)
i wouldnt get that processor, a 4850e x2 low power 45w processor would be better cutting down on your electricity costs, unfortunately you'll have to get that from elsewhere as oc'uk dont stock it. some new low power 65W phenoms are coming out too in the future which you can look at.
do you need 7.1 hd sound to be outputted?
then you need to add a cheap ati 4xxx series gfx card to lpcm 7.1 output
or a Asus ASUS Xonar HDAV1.3 for proper DTS-HD Master, Dolby TrueHD etc. output
780g mobo is better though dedicated decoding chips.
Or you could do it properly and buy the option spdif out module and connect it up to an AV receiver or stereo.
The G45 is a better board, does the full decode and support 7.1 full resolution LPCM via HDMI. The boards cost more but you won't need to get a XOnar HDMI down the line which costs silly money.
E2180 (small OC to 2.6Ghz~) (run stock cooler 5v)
DG45ID / DG45FC
2GB cheapest RAM (no reason at to double it)
LG BD/HD-DVD drive
Corsair VX450
Whatever case you fancy (if Antec their included PSU's are good)
why? I'd be more tempted to undervolt it and see how little power you can get it to use.
A lot of people download 1080p x264 encodes, a lot of these won't work under DXVA and need some grunt, but actually not as much as I said. That would be for playing AVC off of a BD in software.
