DaveyD said:Well if it's got a VGA port on it, it'll work fine.
Maniac618 said:I have an LG L1710B
Anyone able to check if I could use it with the 360?
Maniac618 said:so is the LG me and you have AdWright actually HD, or is it not? Is it true HD? I would have thought it is because it's higher than the standard TV resolution, or is there more to it than that?
DaveyD said:HD is just a resolution at the end of . PCs have always had a HD resolution of gaming for the last decade anyway.
True HD, ideally, for 720i/p (1280x720) and 1080i/p (1920x1080), you need a widescreen display, 16:9, but you're getting that through the VGA cable.
