i3 2120 - Single fan - Prodigy
23 May 2011
The board I have only has a single header for case fans so I was wondering if anyone has used an i3 2120 with only a single exhaust fan? The GPU should take care of itself as it's a reference cooler and as you may know the Prodigy has a big area of holes right next to the GPU meaning it should look after itself as far as airflow goes but I'm worried the CPU might get a bit toasty.
Also if a single fan will be fine do you recommend having it intake or exhaust?
Just pickup a couple of Molex to 3pin adapters. If not then if you make the rear exhaust inwards you should have decent enough airflow.
