Got my i3 530 bundle on friday and finally got it put together on saturday, on the whole very impressed and all seems good apart from a couple of niggles.....
The acrtic freezer cooler had one of the black pushpins missing from the installation kit bag, not a major problem, cut a ziptie down to a stub and used that instead; worked just as well as the OE pins.
The fan will not start spinning on its own, when I power on it jumps a tiny amount and then stalls, it will start up if you give it a push/flick. Assuming there arent any bios settings that I should change, I guess Ill have to RMA the cooler
I cant seem to get the powering on and off of the motherboard to work as expected, Ive plugged all the front panel cables (power, reset, HDD light, speaker) into the respectively labeled positions on the socket. When I restart the machine (either from windows or exiting bios) it just shuts down and I need to do a hard power on again. The reset switch doesnt reset the board, instead turns it all off and the power button wont turn it off either; need to turn off the psu.
Occasionally after having to restart, the board will hang on post and never beep (indicating 100% cpu load according to the leds on the motherboard), need to pull the plug (as the reset button doesnt work). Usually if this happens the bios posts an overclocking/voltage failure and resets the clock, I then have to go into bios and set the clock back to 4ghz. Because it doesnt restart from save & exit bios this error quite often re-occurrs
Any thoughts? Its quite annoying having to leave my case open in order to manually start the cpu fan and constantly reset the overclock in bios.
Specs are: -
i3 530 @4ghz
Gigabyte GA-H55M-UD2H
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
Arctic Cooling Freezer 7 Pro Rev 2
Zotac GTX260 216
2x 150Gb sata hdd
Cheiftec dragon case
2x80mm front intake, 2x80mm rear exhaust
Specs are: -
i3 530 @4ghz
Zotac GTX260 216
2x 150Gb sata hdd
