Basically, would it be easier to overclock a higher speed (in the first place) chip than a lower one?
I wanna know if you'd usually achieve say 4GHz with lower volts on a 560 than you would have to put through a 530?
Please bear with me, and I know these chips are the 2 extremes of the i3. I want an i3 for my M-ITX HTPC, but want it to be as cool as possible (ie, not much extra volts!)
