i3 6100 - i5 6500
12 Dec 2005
i5 6500's are going for about £90 on the MM it seems. I recently bought an i3 6100 brand new and I think it's bottle necking with my 470. Is an i5 6500 much of a step up
Check out this youtube link:
https://www.youtube.com/watch?v=xJuadijvTSU
i5-6500 vs i3-6100 | GTX 970 OC | 2560 x 1440
Granted this is a 970, but there are a few FPS different most the time, i dont know why you think the CPU is a bottleneck in your setup,i dont know what resolution you game at, or what FPS you get in your current games, or in fact much about any of your setup, but for the money you would spend on changing your CPU, i don't think you will see much gain in performance.
:confused: That's the exact video I linked.
Honestly if I were you OP, if you have a compatible motherboard and suitable cooling, I'd try overclocking the i3 before spending more money, and see how much performance you gain. If you don't gain anything, then you're not CPU limited, and upgrading will not likely show much benefit.
Be sure to use msi afterburner/rivatuner stat server to put cpu and gpu usage overlays on, if you don't already.
I don't really think you can overclock i3's can you? The issue I'm having is when I'm playing Overwatch I'm at 60FPS most of the time but sometimes when I dip below this I'll get stutters and I assumed it was because of the i3 and my 470
Yeah there's non-K overclocking available on certain skylake boards, you just have to make sure you're using the correct BIOS revision, as on later boards/revisions it was patched out.
OCUK used to sell pre-overclocked non-k skylake bundles if I remember correctly.
What motherboard do you have?
i3-6100 can be overclocked on quite a lot of boards, I was contemplating it before going with my i5-6400. I have that running at 4.5Ghz, your i3 should be able to hit something similar.
Not sure what settings and res you are on but Overwatch on an i3-6100 and 1060 my wife's computer maintains over 100fps on ultra at 1080p. I've been thoroughly impressed with the i3-6100 and 1060 combo :)
I use an i3 4130 with a 1060 and it's all good. I avoided an AMD offering as I know a lower end CPU would struggle with an AMD card.
Glad you have found the issue.
Now get that processor overclocked and see how you get on!!!
