- 10 Nov 2009
- London
I've been speccing up an i3 based HTPC. Using the H55 chipset the benchmarks suggest that the i3's Integrated GPU is good enough for normal HTPC stuff. Is also supports direct bitstreaming from Blu-Ray, which otherwise you'd need a Radeon 5xxx for.
Here's the spec:
I'd like to add the £35.99 mini-ninja, but it doesn't support the socket
It's a little pricey at the moment, but I would hope prices will come down a bit since both the i3 and H55 are still very new. I'd definitely jump for £450ish.
So, is this a sensible build? can it handle the HTPC load without an aditional GPU? Is 2GB RAM enough? This year will see the release of DVB-2 (Freeview HD) tuners, so it seems like an ideal time to go HTPC.
Edit: Changed to use cheaper mobo
Here's the spec:
