- 26 Sep 2013
Need mobo and 16GB ram to go with this chip, mobo must have a PCI slot. Machine is for audio/video/photo editing, not gaming. Any advice would be appreciated. Thanks!
How much do you want to spend? If you are willing/able to spend around £250 the Asus Z97-WS is apparently a good solid board for productivity, they support advanced and fast storage solutions and can be easily expanded with Thunderbolt connections for NAS etc if you are using one and they claim to have exceptional stability and reliability.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-631-AS
Thanks but this looks like overkill, i have no need for any of the stuff you've described! Plus, no PCI which is essential.
it is a heavy weight board for serious productivity and is expensive, most of the things I mentioned are for things like large but rapidly accessible external storage to protect and backup the data your working on as you actually work on it etc. The overbuilt nature of the card is for long term reliability with constant or heavy usage.
It does have PCI slots though, 4x PCIe 3.0/2.0 16x, 1x PCIe 2.0 x4 and 2x PCIe 2.0 x1
But the other guys suggestion is certainly better value, especially if you don't need those features.
That Gigabyte board is fine.
The RAM is 2400MHz and under £100
What more do you want?
I realise what all the features are for, i just don't need them. The ports you lisi are all pcie...?
You meant the old PCI? Nevermind then, my bad thought you where just shorthanding PCIe.
There is one board not listed anymore at OcUK called the Gigabyte Z97 sniper - http://www.gigabyte.com/products/product-page.aspx?pid=4952#ov
SLI/Crossfire support.
Killer NIC.
But more importantly Creative Core3D sound, Nicichon capos and op-amp upgrade option.
You said your sound card was old and PCI, this one board will allow you to chuck it in the bin I think.
