- 6 Sep 2008
- By the sea, West Sussex
Hey All,
Got a bit of a weird one I can't put my finger on.
Wife and I have HP Probook 6460b laptops with I5 2450M CPUs.
Only difference is that she has 2x4GB RAM and I have 2x8GB RAM.
I built the laptops with the same disk media and the same set of drivers and built the same way, yet a few months in my wife is complaining hers is slow.
After digging about and not finding anything obvious I run resource monitor and find the CPU maxing out. A little more digging and i find the CPU is running at either 775Mhz or 975Mhz (8x and 10x multipler respectively).
If I run CPU-z and run Prime 95 mine ramps up to full speed and occasionally turbo boosts. If I do the same on my wifes, 975Mhz is the most is sees.
I've checked the BIOS settings and as far as I can tell everything matches and I gone through the power options and they seem to match too.
I'm beginning to suspect and faulty CPU, but can anyone suggest anything before I start some hardcore testing.
