i5-2500 only running at 1.59ghz?!
This is most likely to be speedstep at work - the processor will automatically lower its clock speed when idle to save power.
Put your machine to work, and it should increase to the normal value :)
Yep mine does that too, it's to reduce power consumption when you don't need the extra performance. Run something processor intensive and it'll go up to 3.3-3.7ghz.
