CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.4.0
Monitoring
Mainboard Model P8P67 (0x00000145 - 0x0002DE70)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6776
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC3
LPCIO Revision ID 0x33
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF C0 7E 03 00 FF FF
20 C3 33 FF 00 20 00 00 00 00 FF 68 00 80 00 00 01
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6776
Voltage 0 1.30 Volts [0xA3] (CPU VCORE)
Voltage 1 12.19 Volts [0x7F] (+12V)
Voltage 2 3.36 Volts [0xD2] (AVCC)
Voltage 3 3.36 Volts [0xD2] (+3.3V)
Voltage 4 5.00 Volts [0x7D] (+5V)
Temperature 0 46°C (114°F) [0x2E] (Mainboard)
Temperature 2 62°C (143°F) [0x7C] (CPU socket)
Temperature 3 73°C (163°F) [0x49] (CPU)
Fan 1 1464 RPM [0x5B8] (CPUFANIN)
Hardware registers
bank 0
00 04 FF 04 FF 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 FF 00 FF FF FF FF FF 00 00 00 00 00 86 00 00
20 A4 7F D2 D2 7D FF 39 2E FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 FE 48 FF FF 38 3F FF 2D FF FF FF 18 05 00 A3
50 FF FF FF FF FF FF FF FF C1 FF FF FF FF 05 00 FF
60 00 FF FF FF FF 01 07 FF FF FF FF FF FF FF FF FF
70 00 0A 00 49 80 49 80 49 80 FF FF FF FF FF FF FF
80 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4
A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 01 01
B0 00 00 00 00 00 00 3B 00 1C 00 00 34 28 40 C4 FF
C0 01 00 00 00 00 00 00 00 00 06 01 FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 1
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
bank 5
bank 6
bank 7
Hardware monitor ACPI
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Hardware monitor AMD ADL
Voltage 0 0.95 Volts [0x3B6] (VIN0)
Temperature 0 58°C (136°F) [0x3A] (TMPIN0)
Fan 0 1401 RPM [0x579] (FANIN0)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.223 MHz
Sys timer 1.000 KHz
BCLK timer 99.98 MHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 2500K
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Tjmax 98.0 °C
Core Speed 4399.0 MHz
Multiplier x Bus Speed 44.0 x 100.0 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 59x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 59x
Ratio 2 cores 59x
Ratio 3 cores 59x
Ratio 4 cores 59x
TSC 3300.0 MHz
APERF 4400.7 MHz
MPERF 3300.6 MHz
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020105h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000206A7 0x00100800 0x1F9AE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B0FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D356920 0x30303532
0x80000004 0x5043204B 0x20402055 0x30332E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00001000 0x70012100
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x3B3B3B3B
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001FC 0x00000000 0x0004005F
MSR 0x00000601 0x18141494 0x80001FFF
MSR 0x00000602 0x18141494 0x80000104
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x800087F8 0x001487F8
MSR 0x00000611 0x00000000 0x05F6C97C
MSR 0x00000639 0x00000000 0x051B2B68
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x01E002F8
MSR 0x0000019C 0x00000000 0x88140000
MSR 0x000001A2 0x00000000 0x00621200
MSR 0x000001B1 0x00000000 0x880F0000
MSR 0x00000198 0x00002BB7 0x00002C00
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x02100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x05F7F3D4
MSR 0x00000639 0x00000000 0x051C27C8
MSR 0x0000019C 0x00000000 0x88100000
MSR 0x000001B1 0x00000000 0x880E0000
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x04100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x05F9221B
MSR 0x00000639 0x00000000 0x051D32E4
MSR 0x0000019C 0x00000000 0x880F0000
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020105h
CPUID
0x00000001 0x000206A7 0x06100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
