i5-2500k or i5-3570(non-k)
11 Feb 2007
London / Essex
Trying to use some old hardware to make gaming/productivity rig in the spare bedroom, will be connected to a 40" 4K tv other hardware is a Asus Gene V, 16gb ram, 128GB M4 SSD and a GTX980ti powered by a AX760i, not sure if ill be overclocking and want to run air cooling.
Thanks guys.. only just noticed the 3570 is actually a 3570k should I still stick to the 2500K ?
In that case I would be testing them both, but would probably end up delidding the 3570k and using that.
If you want less faff, just drop the 3570k in and give it a small overclock and be done.
Unless it happens to be a real poor example, running hot with even a small OC...but then we are back to delidding.
But if you want to play, then play. I would play :P
Get the i5 3570k for pcie 3.0.
I had a i5 2500k that could not over clock over 4.4ghz.
My i5 3570k can over-clock to 4.7ghx
