All,
I'm currently trying to achieve the highest stable OC I can get out of my 2500K. I initially had several BIOS issues with my P8Z68-V Pro/GEN3 but I've finally managed to cure all those niggles and have a stable motherboard with the latest BIOS (3202).
My current modest OC is 4Ghz @ 1.36v withe the H100 cooler, temp. around 62C. I know that the voltage is on the higher side and that's where my question arises. While overclocking, there are a few ways to set voltages:
1. Set voltage Manually by entering required values
2. Use Offset mode, to enter either a +/- offset value
3. Auto
I am current set at the offset mode, with the offset value at Auto. And with that setting for voltages, I get a Vcore of 1.36v under load. Looking at the other posts here in the forum, that looks to be quite high for a 4Ghz OC.
So, I would like some guidance on what's the best way to set voltages. Secondly, which are the other parameters in the BIOS that I can tweak to get a Stable OC, with less voltage & heat?
3. Auto
) but you can probably ignore the memory side of things.
