- 30 Sep 2009
- Beccles, Suffolk
Hello i'm still a newbieat this so i'm just checking if this is ok. Any advice is really appreciated
Asus P8Z68-V, i5-2500k, Kingston HyperX Genesis 8GB
Ai Overclock Tuner - Manual
BLCK/PCIE Frequency - 100
Turbo Ratio - By All Cores
By All Cores - 46
Internal PLL Overvoltage - Enabled (not sure why)
Memory Frequency - 1600
EPU Power Saving Mode - Disabled
Dram Timing Control - 9-9-9-27 2T
Load Line Calibration - High
VRM Frequency - Manual
VRM Fixed Frequency - 350
Phase Control - Extreme
Duty Control - Extreme
Current Capability - 100%
CPU Voltage - Offset Mode
Offset Mode Sign - (-) minus
Cpu Offset - 0.030
Dram Voltage - 1.55
VCCIO Voltage - Auto
CPU PLL Voltage - Auto (dont know if i need to raise a little bit)
PCH Voltage - Auto (unsure)
CPU Spread Spectrum - Disabled
Results in (for me)
Idle - flucuates between 0.976 - 0.984
Load - flucuates between 1.336 - 1.344
I selected IBT for stabilty testing
20 runs standard
40 runs maximum (max temp 71c)
didnt want to go any further untill i got some advice, thankyou
By All Cores - 46
Cpu Offset - 0.030
Dram Voltage - 1.55
Results in (for me)
20 runs standard
