My specs:
i5 2500k @4.5 Ghz
Gigabyte GA-P67A-D3-B3
Kingston HyperX Blu 2x4GB
GTX 970
Cooler master hyper 212 evo
I have been running an overclock of 4.5Ghz on my 2500k for a few year. I really dont know a great deal about overclocking but I originally followed this guide as I have a very similar gigabyte motherboard.
At first (about 3 years ago)I was very stable with only around 1.3V but as time goes on I find I keep needing to increase the voltage more to get stability to the point where I need to run the chip at 1.416V for it to be stable. This is also increasing my temps a lot I get around 75 degrees after running prime 95 for 20 mins.
Could the chip be starting to die? is 1.4V+ even safe? and is 75 degrees under load okay at that temperature?
My other bios settings are pretty much the same as on the guide above as I don't really understand many setting like what the "QPI/Vtt voltage" and "system agent voltage" are. Could changing any of these improve my stability so that I can run at a lower voltage?
Thanks in advance
i5 2500k @4.5 Ghz
GTX 970
Thanks in advance
