i5 2500k Overclocking help :)
4 Mar 2008
Wandsworth
Hi guys just after some help with overclockong my 2500k :)
got the z68 asrock extreme4 and was hoping to get around 4.8Ghz
Currently got it set to 48x multi and everything else set to auto except the vcore which i have maulally set to 1.4V is this a safe voltage?
Boots into windows fine with those settings
I have disabled speedstep, however for some reason it still seems to be lowering the multi?
when it boots the multi is all the way down at 16x :( aven while running IBT its only gone up to 42x :/ what do i need to to get it to stay at 48x?
ta
I got given this link, it was really helpful. Your multiplier will not max out until you set your turbo boost power limit like that in the video. Its the same board as yours too.
