i am using a 15 2500k cpu , and i have it on a msi gen 3 mobo , problem is overclocking , when i run linx the cpu clock goes from 4.2 ghz to 4.7 at random times , i set the oc at 4.7 what do i need to disable on the mobo or cpu to stop it under then over cloking ?
seems to do do 4.7 with 100 runs in linx nps , but as soon as i set it to 4.8 blue screen after a few seconds, tried upping voltage and nothing , anything else i should try and adjust?
