i5 2500k Purchase
Permabanned
14 Dec 2008
Sunderland
I am on the verge of purchasing an i5 2500k as I can get it relatively cheap. Can anyone recommend me a solid cooler and motherboard to go with it.
Probally best off going with a Z77 chipset motherboard now, I woudn't like to reccomend any though, not a lot of people are using them yet to say which is best, but the ASRock ones are good value for money.
Gigabyte got UK RMA for warranty, that's why I chose them, they have some budget orientated ones - check them out also.
£119.98 inc VAT - Asrock Z77 Extreme4 Intel Z77 >> http://www.overclockers.co.uk/showproduct.php?prodid=MB-064-AK
£101.99 inc VAT - Gigabyte Z77X-D3H Intel Z77 >> http://www.overclockers.co.uk/showproduct.php?prodid=MB-390-GI
£25.99 inc VAT - Gelid Tranquillo >> http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD
y dont you practice what you preach:p
The above statement makes no sense.
I posted to point out your odd behaviour.
Sending trust messages instead of posting whatever you want to say is suspicious.
It looks like you're doing something that isn't allowed in the forum.
