- 20 Sep 2009
Hi guys, Havent really been here since i bought my E6550 dual core setup and that has lasted me a good 5 years (clocked to 3.2ghz).
Struggling to run BF3 on low now however, need some suggestions
Iv compared processors and im on a bit of a budget so i decided on a i5 2500k
few questions...
What is the best type of memory to use? Dual channel? 1600mhz?
What is considered the best budget mboard? Im looking to clock it around 4.5-4.6ghz fully stable
My gfx card is a HD 5770 - Will this bottle neck things? I bought it quite recently to go with my 22" widescreen monitor.
Also probably most important i have a corsair 520w power supply, will this provide enough juice?
Thanks for any help.
E6550 @ 3.ghz
4gb geil 800mhz 4-4-4-12
HD 5770 1024mb
150 Gb Sata
Corsair 520w
Buget Cheap as possible no more than £400
few questions...
E6550 @ 3.ghz
HD 5770 1024mb
150 Gb Sata
Corsair 520w
New BIOS gives it Ivy Bridge support, but I don't think it will do PCI-E 3, and it is rather more expensive that your original choice...
