So, you've won me over... an AMD enthusiast converted - Sandybridge wins!
....never thought that would happen!
So the AMD gaming 4800+ skt 939 rig gets an Intel rebuild;
CPU is a no brainer - i5 2500k
MOBO was a harder choice, I've gone mid table as I've seen Z79 recalls and Z68 gen3 is now 'last year'... ASRock Z77 Extreme 4 has become my price point mobo for sub £120 board - it gives me some future to slap in the 'sweet' ivybridge when it emerges...
RAM is even harder
but I've worked out that 1600Mhz is the sweet spot for Sandybridge... with some headroom to OC, so; Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Tactical Memory Kit CL8 (8-8-8-24) 1.5V at sub £45 seems to be my goal.
It will run stock on arrival and then next month I will cool with a H100 and see if 5ghz is attainable.
I'm going to put my curent SLI combo of 9600GSO xxx in for the time being... given 6 to 12 months there will be a new set of gfx cards in play!
Your wisdom - as ever - is appreciated before I hit 'pay'
RAM is even harder
but I've worked out that 1600Mhz is the sweet spot for Sandybridge... with some headroom to OC, so; Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Tactical Memory Kit CL8 (8-8-8-24) 1.5V at sub £45 seems to be my goal.It will run stock on arrival and then next month I will cool with a H100 and see if 5ghz is attainable.
just in case it starts to get tight, dependant on my after market choice of cooling solution, which is not fixed in stone yet. The i5 will be on its stock cooler until I've seen the motherboard for myself
I wasn't aware that lower timings were of no value in the case of the sandybridge, although I'd read that it does like speed, 1600 being the sweet spot?
