Hi,
I've just invested in a new system, the guts are below, I have a 140mm Xigmatek XLF-X1453LED Fan blowing in on the front of the case an Eco A.L.C. for the CPU with the fan on the radiator blowing out of the rear of the case and the 120mm fan that comes with the CoolerMaster case blowing in at the top of the case, I've also blocked the empty fan sections.
From boot to idle the temps are between 38-40ºC, under load it's between 58-63ºC.
My question is, should I be expecting more from the Eco or are the temp as expected with liquid cooling?
Code:
Intel Core i5-2500K 3.30GHz Processor
Asus Sabertooth P67 Socket 1155 Motherboard
Corsair 8GB 1866MHz CL9 DDR3 Vengeance Memory Two Module Kit
Asus GeForce GTX 550 Ti 1GB
Cooler Master Elite 430 Black Tower Case
Coolit Systems Eco A.L.C Watercooling System
