No point in overclocking a processor so much bro, just a tip, clock speed is the least reliable performance factor, in other words its not as important as for instance, MIPS or FLOPS of the actually chip. So once again, oc'ing the chip to 5Ghz is going to gain you very little![]()
go for a 2600k HT off should be easy for 5ghz
plus you gonna need luck on the chip i heard the 2700 dont clock as good now since IB been out so unsure if that also affects the other 2
Just bought a 2700k with asus z77 v pro.
Does 4.5ghz on stock volts. More overclocking tomorrow....
Did You get that cpu from ocuk or eles where.
