i5 3570k Overclock Temps?
29 Dec 2009
For a friend:
Got an i5 3570k at 4.4GHz / 1.4v pre-built system from Overclockers that I replaced the cooler with a Corsair H60 as it was crashing/overheating.
I've never overclocked an i5 before so not sure what the guidelines are.
Is 1.4v "safe" for long term? I know with i7's it's a bit much..!
Load temp still reaches 90'c with the H60.
Am I expecting too much from the H60 or should load temp be a lot lower than that?
My main rig also uses both a 3570K and H60 cooler. I can manage 4.2GHz at 1.16v and temps never exceed 70°C on even the hottest of days. If I push onto 4.4GHz, I need a lot of extra voltage.
In my opinion, the volts, heat and additional noise associated with those additional 200MHz are just not worth it for the tiny gains :)
Thanks, though as much.
Will lower it down to 4.2GHz and see how low I can get the volts.
It started crashing (locking up / no bsod/restart etc - so not enough v I guess)
I'm used to my nice lower voltage 4790k at 4.5GHz running no warmer than 70c :p
Maybe you're actually just over volting it?
Mine runs 4.4 GHz by setting the turbo to 44 on all cores and I've set the voltage to 1.18v
With a Noctua air cooler and running Prime95 with small FFTs I get 51 DegC on the hottest core after ~10mins (I had to check that because I initially thought I was doing something wrong!)
1.4v does seem a lot of v for 4.4ghz tbf
your probably running a fixed cpu voltage aswell rather than utilising intel speedstep,that would give you much lower idle temps atleast
at a rough guess you should be aiming for around 1.25-1.32v for 4.4ghz/4.5ghz
unless you have a real dog of a cpu
what motherboard? learn to clock through cpu/offset or dvid so it clocks down in speed/cpu voltage at idle
Thanks a lot, will have another go in a couple days when I go to my friends again.
I'm a bit rusty as my i7-4790k goes to 4.4GHz by itself so haven't bothered playing around for a couple years!
