- 19 Jan 2013
Hello,
I am trying to overclock my first system and need a little advice.
My new setup looks like this:
i5-3570K
Gigabyte Z77X-UD3H
Corsair Vengence 1866
Noctua DH-14D
I have worked it up to 4.5Ghz stable at 1.1v with a peak temperature of 61 degrees (based on 3 and a bit hours of Prime 95 running although I will leave it running tonight for confidence). All I have really changed in the bios is the turbo clock to 45 multiplier and vCore to 1.1.
This is my latest stats:
http://imageshack.us/photo/my-images/4/printscreenyz.jpg/ (sorry can't get image to appear in post
I have 3 questions:
Firstly does this seem right (this speed with this voltage) as I have been reading around and it seems a little low?
Secondly Core 1 always runs about 5 degrees cooler than the rest, is that Ok?
Finally I only change the turbo speed so it will spin up and down as needed, is there a way to do this with the voltages as well to make it more efficient without using "Auto"?
Cheers
Niall
i5-3570K
Gigabyte Z77X-UD3H
Noctua DH-14D
)I have 3 questions:
Cheers
Niall
there to get those volts and temps @4.5GHz There seems to be absolutely nothing wrong here from what I can see. I cant get anywhere near those results, (to be honest I doubt many can) So I'd keep it like it is.............No Wait! I just noticed on your image that your running Prime version 25.11 Download Prime95 version 27.9 and then post your results once again via image, there will be a huge difference in results I can guarantee you that!
