hi basically im new to overclocking and had a good read up on the internet to see roughly what i should be getting from my cpu with rough voltage and temps,
firstly i over clocked using cpu level up with asus at 4.6ghz, 1.330 volts, and idle temps of 30c and load temps of 70c during a 3 hour blend test on prime 95 and everything was fine but i wanted to lower volts as it seemed to high
so i then changed it manually to 4.5ghz, 1.170 volts and idle temps of 28c and load temps of no higher than 49.7c and ran it on prime 95 blend for 2 hours and it had no errors or warnings, i even checked windows event viewer and it was all ok,
does this seem ok to you? im not an expert on overclocking but these temps seem really low and the volts seem low to be on 4.5ghz, is there something i need to worry about here?
any advice would be very welcome cheers
its a custom water cool set-up and im using a maximus vs formula mb
