What kind of voltages should I be getting at 4.4ghz?
I've been following guides etc I've found to try and use the offset voltage, but it seems to be really high (1.288 at 4.4ghz) which seems odd.
I tried using fixed voltage and lowering it and nothing, doesn't want to boot, keeps crashing.
Bit of a noob as you can tell but any help or link would be appreciated.
asrock z77 extreme4
i5 3570k
Cheers
asrock z77 extreme4
i5 3570k
Cheers
