I5 4590 + RTX 3080
5 Nov 2014
So, i might have to bring my upgrade plans forward
ACC ultrawide 34inch 1440p resolution. All high settings
Practise with no other cars = 140fps
Full grid race = 65fps
I didnt realise the impact a cpu could have
Significant CPU bottleneck is likely. No way a Haswell chip is going to be taxing a 30 series card - the same problem for me if I upgraded :p.
That CPU is 7 years old so you can't really expect to run a modern high GPU on it even at 4K.
Either a 11400F + B560 if you want a cheap upgrade or go ryzen 5000 if you want to push the boat out, both option will perform about the same at 1440 UW and max out the card.
