Hey guys, so I found this guide linked in another thread made by a member here which had this as a template for;
"Easy 4.4 / 4.6 GHz
CPU VRIN Override LLC: Set to Extreme (this is to make sure VIN doesn’t droop)
CPU VRIN Override Voltage: 1.7-2.0v (reduce if temperatures too high is causing instability, increase if temperatures are fine and you are unstable)
VCore: 1.24-1.34v
Ring Voltage: 1.15 or 1.2v
CPU Multiplier: 44x-46x
BCLK: Auto
Turbo: Auto
C1E, C3, C6/C7, and EIST: All Disabled"
So I looked at doing this in the bios and could use some help in finding/clarifying some stuffs.
The motherboard I have is Gigabyte Z87-HD3 Intel Z87 (Socket 1150)
Does CPU VRIN Override LLC = CPU Vrin Loadline Calibration? If so, Turbo = Extreme?
Does CPU VRIN External Override = CPU VRIN Override Voltage ?
Those 2 I wasn't sure about, I also couldn't find:
"BCLK"
"Turbo" (Unless that's the Intel turbo thing which is already on Auto by default)
Just want to make sure I do it all right before I give it a go, and I'm unsure of those 4 things.
Lastly I suppose oc'ing this cpu to around 4.3 ghz would be a fairly significant increase to gaming/recording performance given I'm currently running @ stock 3.4ghz with my gpu being a 1080 gtx playing at 1440p?
Thanks
"Easy 4.4 / 4.6 GHz
VCore: 1.24-1.34v
BCLK: Auto
Turbo: Auto
"BCLK"
Thanks
