i5 5675C issues
6 Oct 2007
North West
Just picked one up and there is no display output from the GPU via the HDMI on the gene 2, select CPU GPU as the main display and it just reverts back to auto and the dedicated GPU I have in after reboot.
I can't overclock it, it displays the OC settings in the bios but it's all at default in windows.
Doing my head in, is it the CPU or mobo....
Noob question, but did you check for the bios revisons for the mobo?
Can't you use the cpu gpu for physx as with haswell?
Hmmm. Yeah. Looks like.
Do you have a different mobo you could try?
Some mobos support 5th gen and some don't.
Not sure if this would mean that you just don't see the cpu gpu or that it is not working at all.
I don't have any experience with broadwell to be honest, just brainstorming now :)
