- 1 Feb 2008
i5 750 overclock, my 1st attempt UPDATE PAGE 2 !
hello guys,
So i have just set up my new pc, got it running all smooth on standard clocks.
Now i have gone onto overclock my computer,
I have been reading loads of guides and i decided i wanted to overclock my i5 750 to 3.6ghz on stock voltage, i wanted stock voltage as i saw some graphs of when you increase the cpu voltage and what it does to the power consumption !
I have set my blck freq (think its called that) in the bios to 180 and as my multiplier was 20 that would hit 3.6ghz.
ofc turning off speedstep in the process.
It booted into windows fine, and i have began "stress testing" with prime95.
Monitoring the cpu temp with speedfan aswell.
Here are my current results :
Uploaded with ImageShack.us
I havnt seen my cpu temps go above 60*c when stressing it with prime95, Is this an ok temperature? Is it going to rise much above this when gaming?
Also i have the side of my case off atm, im hoping that will not change when i put it back on.
As you may be able to see that i have not touched the qpi speed,
i would quite like to know what to change it to? or what to set it at ect?
Just after some hints and tips from you overclocking pro's
My motherboard is a Asus P7P55D-E.
Thanks for your time !
hello guys,
