Looking to overclock my I5 750 but not really sure what clock is possible on my mobo.
See spec in my sig
CPU-Z
Binaries
CPU-Z version 1.57
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Package (platform ID) Socket 1156 LGA (0x1)
CPUID 6.E.5
Extended CPUID 6.1E
Core Stepping B1
Technology 45 nm
TDP Limit 95 Watts
Core Speed 3205.3 MHz
Multiplier x FSB 24.0 x 133.6 MHz
Rated Bus speed 2403.9 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max turbo frequency 3200 MHz
Max non-turbo ratio 20x
Max turbo ratio 24x
Max efficiency ratio 9x
TDC Limit 89 Amps
Core TDP 89 Watts
Uncore TDP 6 Watts
Power @ 9x 14 Watts
Power @ 10x 17 Watts
Power @ 11x 20 Watts
Power @ 12x 25 Watts
Power @ 13x 30 Watts
Power @ 14x 36 Watts
Power @ 15x 43 Watts
Power @ 16x 51 Watts
Power @ 17x 60 Watts
Power @ 18x 70 Watts
Power @ 19x 82 Watts
Power @ 20x 95 Watts
Max bus number 63
Attached device PCI device at bus 63, device 2, function 1
Attached device PCI device at bus 63, device 3, function 4
Chipset
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 534.2 MHz (2:8)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 59
Command Rate (CR) 1T
Uncore Frequency 2136.8 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Max bandwidth PC3-8500F (533 MHz)
Part number CM3X2G1600C9DHX
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-18-24 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-23-31 @ 609 MHz
JEDEC #4 9.0-9-9-26-35 @ 685 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
Monitoring
Mainboard Model Maximus III Formula (0x000006D5 - 0x737EC7E1)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83667HG-A
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB3
LPCIO Revision ID 0x53
Hardware Monitors
Hardware monitor Winbond W83667HG
Voltage 0 0.89 Volts [0x6F] (CPU VCORE)
Voltage 1 1.72 Volts [0xD7] (VIN1)
Voltage 2 3.38 Volts [0xD3] (+3.3V)
Voltage 3 5.06 Volts [0xD3] (+5V)
Voltage 4 11.88 Volts [0xD5] (+12V)
Voltage 6 0.82 Volts [0x66] (VIN6)
Temperature 0 30°C (86°F) [0x1E] (SYSTIN)
Temperature 1 31°C (86°F) [0x3D] (CPUTIN)
Temperature 2 36°C (96°F) [0x48] (AUXTIN)
Hardware monitor Analog Device ASP0800
Current 0 7.90 Amps [0x3F3] (CPU)
Power 0 7.87 W [0x3EF] (CPU)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.88 Volts [0x36B] (VIN0)
Temperature 0 51°C (123°F) [0x33] (TMPIN0)
Fan 0 1620 RPM [0x654] (FANIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
See spec in my sig
CPU-Z
Binaries
CPU-Z version 1.57
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processor 1 ID = 0
Codename Lynnfield
CPUID 6.E.5
Extended CPUID 6.1E
Core Stepping B1
Technology 45 nm
TDP Limit 95 Watts
FID/VID Control yes
Max turbo ratio 24x
TDC Limit 89 Amps
Core TDP 89 Watts
Uncore TDP 6 Watts
Power @ 9x 14 Watts
Max bus number 63
Chipset
Memory Type DDR3
Channels Dual
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP no
Monitoring
LPCIO
LPCIO Chip ID 0xB3
Hardware Monitors
