hi all
Recently decided to build my first PC following an article in Custom PC mag. Here are my specs: Intel Core i5-750, Gigabyte GA-P55M-UD2, 4gb Corsair Dominator ddr3, Antec NeoHE 430W PSU, Samsung 502HI HD, Antec Mini-P180 case, AC Freezer 7 Pro Rev.2 cooling CPU plus 1x120mm and 1x200mm case fans.
All runs ok at stock speed running 30C at idle and 58C on prime95 small fft test. However, its when i start overclocking that i get problems, and i can't seem to work out why
I used the following settings from Custom PC mag to do the overclock up to 3.8ghz: Intel Turbo Boost disabled, Base Clock control enabled, BCLK 190mhz, System Memory Multiplier 8.0, Load-Line Calibration disabled, CPU V-core 1.45, QPI 1.35, PCH CORE 1.32 CPU PLL 2.00 DRAM voltage 1.600.
When running prime 95 no errors (temps about 80c - abit higher than i would like) are returned but the interface becomes unresponsive (no response to mouse movement or keyboard strokes). I normal use the it can also do the same. Sometimes the computer won't boot up at all. Any ideas? I figured i could just use the figures quoted in the mag and hey-presto, but apparently not...
Any help would be appreciated, thanks
