On s775 cpu's, vid is basically the voltage intel states that each particular chip requires to run at its full stock speed, ie speedstep/c1e disabled. VID ranges vary depending on the particular chip, q6600 for example, mine was a 1.2750, some were 1.200 ono, the highest on the q6600 is 1.325, gennerally chips with lower vid's tend to clock higher, sometimes at the expense of running hotter.
