i5 750
23 Nov 2005
Kingdom Of Fife
Guys put together an i5 750 at stock on an ASUS p55 Deluxe (new work AV PC) The temp according to HW in the BIOS is 41oC idle, I have a Q6600 myself on a DS4, and i am not too familiar with this new CPU I know it has an integrated RAM controller, are these temps OK? I would like to know before I install the OS. I have an Arctic Freezer Pro 7 rev2 cooler, which I have tried re-seating and re-applying AS paste, any thoughts, helpful suggestions?
Jonnygrunge.
i have the same, i5 750 with the arctic pro 7 and my temps in real temp are, sitting idle its 39, 35, 37, 35, i'll take a look in bios for you aswell.
Mine runs between 26 and 29 at stock using a notua top down. I'm using a msi gd-80 and with it clocked at 3.5ghz i'm still getting temps between 31-36 idle. That said 40oC does not seem that high.
so do we think idle temps of around 40 are ok for this cpu ? mine is overclocked to 4ghz with 1.337v and its idling at 41/42 at the moment, i thought maybe this was a little high ?
Mine's idling now at around 34-36 with 1.37v @ 4 GHz using a scythe ninja, seems to be about right, depends on ambient temps of course too.
also remember it artic cooling 7 pro me and op are using, waiting for a few coolers to appear either that or corsair when it fits the socket
nice temps then , i cant get mine below 40c at idle (1.35v) think im going to have to change my cooler :(
