I'm rather new to the overclocking scene so thought I would take on a small overclock and ask for advice before I go diving right into the deep end and end up murdering my components.
I have read through a number of overclocking guides from here and other sites and have managed to achieve 3.8GHz using the following settings which are stable through 3 hours of prime 95 and several runs of IBT using maximum with my cpu temps hovering between 45-49 degrees C.
http://valid.canardpc.com/show_oc.php?id=1725646
Do these settings appear ok to those of you in the know? (Not sure if more info is needed mind) I plan to perform a longer stress test using prime95 over night but thought I would ask here before kicking it off again.
Thanks
Thanks
