I5 build for £300
14 Dec 2008
UK
As title states I would like to know if it's possible to build a I5 rig for £300 no operating system needed, just the desktop.
Need it for a on a budget.
Thanks
Will be fairly difficult as the i5 is £150 or more, and a decent hard drive is around £50. that leaves just £100 for the case, psu, motherboard and ram. (not enough for gpu) Optical drive would add another £20 too
An i3 would be much more reasonable at this price point.
Intel Core i5-3450 3.10GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £154.99
(£129.16) £154.99
(£129.16)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £45.98
(£38.32) £45.98
(£38.32)
XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £41.99
(£34.99) £41.99
(£34.99)
MSI H61M-P31-G3 Intel H61 (Socket 1155) DDR3 Motherboard £38.99
(£32.49) £38.99
(£32.49)
BitFenix Merc Alpha Gaming Case - Black £27.98
(£23.32) £27.98
(£23.32)
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £23.99
(£19.99) £23.99
(£19.99)
Sub Total : £278.27
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £58.00
Total : £348.02
if you find some pre-owned stuff then you may JUST be able to make it
If you reuse your hdd,Psu,case,Gpu and you have win7 from your current system.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £81.98
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £23.99
Total : £297.36 (includes shipping : £9.50).
The OP doesn't say it is to replace his current computer, for all we know it is a new build for someone else.
by all means if the OP has spare components,use them, but those should be stated as available ;)
You can do it easily, the i5 3450 can be had for £140 + £40 mobo + 20 RAM - that leaves you £100 for everything else which is plenty especially when you can get those Case + free PSU for £23 - you could do it for £250 if you shopped around
And why would you want a cheap PSU and case :rolleyes:
You a £40 mobo would have to be H61 so you would need to find out the motherboard revision.
You would be surprised how many people ask for a "desktop" and don`t realise that they can reuse some of there existing components.
Which is why i specced cpu, mobo and ram, to be used with existing parts, as an example.
