Hi,
Just putting together my first build:
i5 2500k, gelid tranquillo, asus p8z68v pro, 8gb hyperx grey, 560ti, 650w coolermaster psu, case is a random 'Mesh' one that im reusing from old build.
I was just wondering which is the best orientation for the gelid tranquillo, as it can be put in 4 different orientations. I was thinking that it should probably be orientated so that the fan is aimed towards the back of the case?
Also going to be using the gelid gc-2 thermal paste that comes with it...what method do people recommend to apply this paste?
thanks
thanks
