Any particular reason for 32 bit Windows 7?
How much difference is there between a 275 and a 5770 or a 4890? Both are a big saving on the graphics card.
5770 all the way
you will get less brute force graphics wise but it is dx11 consumes less power and is quiter and scales amazingly well in crossfire for the possibility of future upgrades
You have DDR2 memory and a DDR3 mobo - just to highlight.
I think the Samsung F3s are in high regard at moment too but someone else will be better informed to advise than me.
Use the money you save on a case to change the graphics to 2x 5770.
Thanks for all your replies...
So, a different Graphics card.. I will look at the recommendations.
Good spot on the RAM, I will make the change.
Regarding the case... anyone with any other thoughts or suggestions? I'm looking for a quiet case and do like the look of my 1st choice.
I notice nobody has advised on any cooling for the CPU, any thoughts on one?
The reason I picked W7 Pro was at it might be used for some work as well as gaming.
Regards
For that price the 275 is pants (it is in the same region as the 4870 iirc)
The 275 is quite a bit better than the 4870, even a GTX 260 is slightly better than the 4870. However you are right that it's a bad choice.
