i5 Cooler Advice
17 Feb 2010
Hi Guys, long time reader, first time writer ;)
So ive been a console whore for about the last 5 year's and got back to the faithfull pc's about a year ago, boy what a difference a half decade makes... talk about changes... anyways.. so i bought a recon P.Bell machine loaded with a q6600 and got back to gaming.. (un)fortunetly my lovely wife started to take an intrest in my mmo gaming (fatal mistake all others be warned ;) ) and before you could say "gizz us a go " i was sharing a pc and buying 2 accounts for all my damn mmo's !! ( stick with me im getting there)
So after much deliberation and emotional warefare i wrangled a £800 budget for a new machine and off i went.... After some browsing and reading of all the builds on this forum ( told you i was getting there ) i settled for this :
i5 750
MSI p55 gd65
Corsair dominator GT DDR3 1600
Corsair vx 550w psu
asus vento TA m11 case
Asus EAH 4890 V.Tweak
AC Alpine 11 cooler
plus monitor and drives ect...
When she found the 900+ bill she was a little unhappy but she got over it :)
so onto the real point of this story....
ive been real happy with the performance but have got the itch to start pushing it a little ;) so i hit the OC button on my board today just to have a looksie...well i got a temp reading of 88 after just 2 mins of P95 !!!!
Needless to say its time for a better cooler so based on my setup ( which i hope is pretty good) its time to turn to you guys for some support / advice...
Ive got my eyes on either :http://www.overclockers.co.uk/showproduct.php?prodid=HS-003-TQ&tool=3
or
http://www.overclockers.co.uk/showproduct.php?prodid=HS-070-AK&groupid=701&catid=57&subcat=1395
Any suggestions would be most appreciated, and thanks in advance for reading through that lot but felt it would be a little rude to just post " what cooler??? " ...
Chao
I have also just built a system and went with the titan fenir ... a lot of benchmarks out there are raving over this cooler.
I run OC'ed at 4.2Ghz with prime temps high 70's and normal full load low 70's
at stock it is substantially lower.
another cooler to consider ... good luck with your OCing
I use the Corsair H50 which is good but expensive. I used to run 4.1Ghz but have moved down to a lower clock but with turbo boost. Low 20's/30's on load, 50's under Linx.
Thanks for the suggestions.... the corsair is a little pricey right now tbh, but the fenrir looks good tho....tbh i cant take my eyes of the tuniq...its a lovely looking monster, think ive convinced myself to get it...not looking to push above 4.ghz so it should do fine ( famous last words !! )
gonna get it ordered.... ty for the reply's...will post up once its delivered and let thee know of the results :)
