Hi, i think ive finally decided to go for an i5 for my new gaming build, and have selected this mobo http://www.overclockers.co.uk/showproduct.php?prodid=MB-368-AS. Is this MB fairly easy to OC with? and is it a good MB? Would you recommend anything else? Also what RAM and CPU Cooler would you suggest pairing up with an i5 and that MB?
Thanks,
Will
Thanks,
Will
