i think you will probably need to up the voltage but you can always try without and see how stable it is. Im at 4.2ghz on the i5 at the moment which required a small voltage boost
mine is sitting at (45*100) 4.5Ghz cpu voltage sitting at 1.37v sitting roughly at 56degrees thts using a stock cooler going to move it onto the water cooling kit over the next few days see what it lowers it to
